TwinTurbo.NET: Nissan 300ZX forum - If you just replace the idle air unit with a straight hose
jzack
on July 13, 2018 at 10:51 PM
My Z won't idle up
posted by Streetsweeper Stafford
on July 13, 2018 at 08:29 AM
connection, car should high idle. If it does this than likely the unit has to be replaced.
My Z won't idle up
08:29:51 07/13/18
Is your TPS set properly? (n/m)
CmyZ
16:34:36 07/13/18
Re: Is your TPS set properly?
19:00:33 07/22/18
If you just replace the idle air unit with a straight hose -
jzack
22:51:00 07/13/18
Re: If you just replace the idle air unit with a straight hose
18:59:41 07/22/18
Did you use the screw adjustment on the side?
FrozTTy
08:03:47 07/14/18
Re: Did you use the screw adjustment on the side?
18:56:31 07/22/18
